Trunking between Cisco and 3COM
May 19th, 2009
I need to setup some trunks between some Cisco switches and 3com switches. Does anyone have any guides or anything that I need to pay attention to or gotchas on both sides. I wont be configuring the 3COM but it would be nice to be able to help out if a problem occurs.
Thanks in advance.
Overall Rating: 5 (1 ratings)
Make sure that the 3COM can create 802.1q trunks.
Find out if the 3COM is manually pruning vlans from the trunk, in case you need to
Find out the native vlan for the trunk.
That's basically it.
switchport trunk native vlan XX
switchport mode trunk
switchport trunk allowed vlan XX (if pruning)
kwillacey Tue, 05/19/2009 - 10:44
The 3COM is capable of 802.1q trunks and i would only need to verify is the pruning and the native vlan. Thanks alot for the info im sure it well help alot if there are any problems.
