MOH File Upload Failure
May 19th, 2009
Hello everyone,
I have this setup with two callmanagers (CUCM 6.0)with the MOH server configured on the subscribe mainly.
I am trying to upload a new MOH file but the pop-up window stops loading or gives the error "Page can not be displayed"
and naturally, the file is not added to the MOH file Management.
I restarted the IP Voice Media streaming service, the CTIManager and eventually the entire UC cluster but the problem is still there.
What could have gone wrong? Any ideas?
Ahmed
Overall Rating: 1 (1 ratings)
ivanromanov Thu, 06/04/2009 - 23:39
Hi Ahmed,
I have the same issue with CUCM 7.
Did you resolve yours?
Ivan
parshah Fri, 06/05/2009 - 10:38
You may be hitting this defect CSCsk61129. Can you confirm that the MOH file you are attempting to upload is in the proper format as required.
AhmedEl-Eraky Mon, 06/08/2009 - 05:11
Actually, I have solved it.
It was a problem in my IE browser, something about the browsers not accepting a security certificate.
I used Mozilla Firefox, added the certificate then tried again it worked!!!
Ahmed
ivanromanov Mon, 06/08/2009 - 05:28
I have resolved mine as well!
It was duplex mismatch between the server and switch with lots of CRC errors. After resolving that I was able to upload files.
Ivan
