UCM bootup error: Err 14: Automatic removal of fake floppy failed
Answered Question
May 19th, 2009
I need help in figuring out why I'm getting this error on bootup. I started getting this error after updating the OS to 2000.4.6sr9. The previous OS ver was 2000.4.4asr7. The server is an MCS-7815-I2-IPC1. CM ver 4.1.3sr8a.
The error is the following.
Err14: Automatic removal of fake floppy failed.
Press any key
The server does not have a floppy drive. Also, the floppy drive is disabled in the BIOS.
Correct Answer by testeven about 7 years 9 months ago
Hi!
Can yoy please try the following?
Reboot server,go into the BIOS setup(F1) and choose "Load Default
Settings"and then "Save Settings", the correct drivers will load at reboot and
server will come up clean.
This is documented in this bug:CSCsg07275
Hope this helps!
Teresa.
If it helps, please rate! :)
Overall Rating: 5 (1 ratings)
Correct Answer
testeven Tue, 05/19/2009 - 13:54
Hi!
Hope this helps!
Teresa.
