Split Tunnel and apple IPhone
May 19th, 2009
I am trying to connect an apple iphone with my ASA using split tunnel, so the user can be connected to our internal server and to the internet; however, when I configure the split tunnel the iphone does not connect with my ASA. If I change to tunnel everything I just connect.
Additionally I have no traffic if I do not use DAP-record. Is there any way I can avoid using DAP and just using the group policy and filter with the traffic?
Thanks a lot
HUGO
vmoopeung Mon, 05/25/2009 - 18:10
Check whether iphone has 2.0 software version because only 2.0 software version has the new capability of split tunneling.
hugo.picado Tue, 05/26/2009 - 08:03
Thank you. I'll try it and let you know.
Do you have an idea why DAP is compulsory in the ASA. I would like to use group policy since I feel is more flexible.
Regards.
HUGO
