paolo bevilacqua Tue, 05/19/2009 - 13:06
  • Hall of Fame,
    Founding Member
Please explain in better detail what problem you're trying to solve.
Jaime Valencia Tue, 05/19/2009 - 13:07
  • Cisco Employee,
  • Hall of Fame,
    2011
That config is not done in CUCM, in CUCM you only create an H323 GW which can contain 1 to N ports (CUCM is not aware of that)
The actual decision of which port to use is controlled by the pots dial-peers, so configure the dial-peers as necessary
java
if this helps, please rate
