CME SIP Call Pick-up
Answered Question
May 19th, 2009
Hi all,
Anybody know how to setup a Call pick-up on CME with SIP using Linksys phone SPA901 ?
I will appreciate any help.
Correct Answer by Adrian Saavedra about 7 years 11 months ago
Try CME Admin Guide configuration examples:
Enabling Call Pickup:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1182075
SIP: Configuring GPickUp and PickUp Soft Key URIs:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1182254
Hope it helps. Rate if it does.
Good luck.
Overall Rating: 5 (1 ratings)
Correct Answer
Adrian Saavedra Tue, 05/19/2009 - 13:49
  • Gold, 750 points or more
Good luck.
paolo bevilacqua Tue, 05/19/2009 - 13:53
  • Hall of Fame,
    Founding Member
The thing is that since the linksys is not a real cisco phone, no "advance" feature will probably work.
Guilherme Masca... Tue, 05/19/2009 - 14:04
Using FAC to have access to the feature I think it should work. On the guide they say "SIP phones that do not support the PickUp and GpickUp soft keys must use feature access codes (FACs) to access these features. " I will try on a Lab environment tomorrow.
Thanks a lot for the ultra fast answer.
etmarcof Mon, 03/26/2012 - 14:40
Hi Guilherme,
Have you managed call pickup working with  SIP linksys SPA901? If yes could you share please your config /CME version.
I'm trying to do the same with Linksys SIP SPA942 without sucess.
Thank you.
Best Regards
