05-19-2009 04:03 PM - edited 03-04-2019 04:48 AM
I have been playing around with EEM scripts to run this cmd every 120 seconds so I can see how many of my voice Channels are in use on my MGCP Gateway which has 3 PRIs terminating on it.
Router# sh mgcp stat | i Inuse
Inuse channels: 4
This way I can monitor all my MGCP gateways in one syslog file for usage.
05-19-2009 11:22 PM
Are you asking how to do this with EEM?
05-20-2009 05:02 AM
Yes, how do you do this with EEM?
I have tried this EEM script, but the timer does not appear to work. It only executes once and displays my routers host name:
event manager applet t1
event none
action 2.0 cli command "enable"
action 2.1 cli command "conf t"
action 2.2 cli command "event manager applet t2"
action 2.3 cli command "event timer countdown time 10"
action 2.4 cli command "exit"
event none
action 1.0 syslog msg "applet called"
action 1.6 cli command "sh int fa2/0 | inc packets input|packets output"
action 1.7 syslog msg "pkts-in/out fa2/0: $_cli_result"
event manager applet t3
event none
action 1.0 cli command "sh int fa2/0 | inc packets input|packets output"
action 2.0 syslog msg "result: $_cli_result"
event manager applet t4
event none
action 1.0 syslog msg "disabling applet t2"
action 2.3 cli command "event none"
alias exec stc event manager run t1
alias exec etc event manager run t4
alias exec eem event manager run
05-20-2009 09:00 AM
I don't see a timer ED here at all. All of your applets have none EDs. However, I see you're trying to configure a timer policy with a countdown timer. The countdown timer only counts down to 0 once, then it never runs again unless it is reregistered. What you want is a watchdog. For example, rewriting applet2:
event timer watchdog time 10
action 1.1 cli command "enable"
05-20-2009 04:42 PM
Thanks jclarke,
It appears that the variable "$_cli_result" will only display the last line displayed (written) by the router, which is the hostname. For Example:
Router1#sh mgcp stat | i Inuse
Inuse channels: 0
Router1#
"$_cli_result" = Router1#, not "Inuse channels: 0" because the return of the hostname is the trigger that the command output is finished, at least that I am thinking.
Router1(config)#event manager applet t3
Router1(config-applet)# event timer watchdog time 10
Router1(config-applet)# action 10 syslog msg "applet called"
Router1(config-applet)# action 20 cli command "sh mgcp stat | i Inuse"
Router1(config-applet)# action 30 syslog msg $_cli_result
Router1(config-applet)#!
Router1(config-applet)#^Z
Router1#
180319: .May 20 17:36:35 PDT: %HA_EM-6-LOG: t3: applet called
180320: .May 20 17:36:36 PDT: %HA_EM-6-LOG: t3: Router1>
Router1#
180321: .May 20 17:36:45 PDT: %HA_EM-6-LOG: t3: applet called
180322: .May 20 17:36:46 PDT: %HA_EM-6-LOG: t3: Router1>
Router1#
05-20-2009 07:43 PM
No, $_cli_result shows the entire contents of the last CLI command. I don't have a router running MGCP, but I do have a 7206 running 12.4(24)T in which show mgcp stat does return some output. The command shows:
UDP pkts rx 0, tx 0
Unrecognized rx pkts 0, MGCP message parsing errors 0
Duplicate MGCP ack tx 0, Invalid versions count 0
CreateConn rx 0, successful 0, failed 0
DeleteConn rx 0, successful 0, failed 0
ModifyConn rx 0, successful 0, failed 0
DeleteConn tx 0, successful 0, failed 0
NotifyRequest rx 0, successful 0, failed 0
AuditConnection rx 0, successful 0, failed 0
AuditEndpoint rx 0, successful 0, failed 0
RestartInProgress tx 0, successful 0, failed 0
Notify tx 0, successful 0, failed 0
ACK tx 0, NACK tx 0
ACK rx 0, NACK rx 0
Collisions: Passive 0, Active 0
IP address based Call Agents statistics:
No Call Agent message.
System resource check is DISABLED. No available statistic
MGCP is disabled. Cannot provide DS0 statistics.
So, I configured an applet:
action 20 cli command "show mgcp stat | i Collisions"
action 30 syslog msg "$_cli_result"
And I see this on my VTY:
May 21 03:40:21.424: %HA_EM-6-LOG: t3: applet called
May 21 03:40:21.456: %HA_EM-6-LOG: t3: Collisions: Passive 0, Active 0
nms-7206a>
So your applet really should work.
05-21-2009 03:29 PM
I tried it out on a different router, actually a production router and it works!
event timer watchdog time 20
Test Router IOS = c2800nm-advipservicesk9-mz.124-15.T1.bin
Test-Rtr#
180358: .May 21 15:43:16 PDT: %HA_EM-6-LOG: t3: applet called
180359: .May 21 15:43:16 PDT: %HA_EM-6-LOG: t3: Test-Rtr>
Test-Rtr#
Production Router IOS = c2800nm-spservicesk9-mz.124-15.T7.bin
May 21 22:45:26.289: %HA_EM-6-LOG: t3: Inuse channels: 15
Prod-Rtr#
May 21 22:45:46.289: %HA_EM-6-LOG: t3: Inuse channels: 16
Prod-Rtr#
May 21 22:46:06.290: %HA_EM-6-LOG: t3: Inuse channels: 16
124.15.T7 is newer that 124.15.T1, I wonder if that is the difference?
Now I can have 4 MGCP Gateways, 6 PRIs, all sysloging this info and GREP'ing to my hearts delight ;-)
Thanks jclarke!
Prod-Rtr#
05-21-2009 03:48 PM
There were quite a few EEM fixes that went into 12.4(15)T7. I didn't see an exact bug for this problem with _cli_result, but one of the fixes could very well have solves some CLI buffer problem. In any event, how you are seeing this work in 12.4(15)T7 is the intended behavior.
