Port persists on vlan1, even after doing 'native vlan 9'
Answered Question
May 19th, 2009
My goal is to unassign all ports from vlan1.
I did the 'switchport trunk native vlan 9'. However, port g0/24 persists on vlan1.
What am I missing?
sw2#show run int g0/24
Building configuration...
Current configuration : 226 bytes
interface GigabitEthernet0/24
switchport trunk native vlan 9 <===========================
switchport trunk allowed vlan 9
switchport mode trunk
speed 100
duplex full
end
sw2#show vlan
VLAN Name Status Ports
1 default active Gi0/24, Gi0/25, Gi0/26
Correct Answer by Giuseppe Larosa about 7 years 10 months ago
Hello Marlon,
'switchport access vlan x' will be effective when port is an access port again
From a technical point of view if the port is a trunk and vlan1 is not permitted on it you can say it is not part of vlan1.
This show reports administrative information.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
glen.grant Tue, 05/19/2009 - 16:37
  • Purple, 4500 points or more
Thats because the access vlan is still 1 , if you change the access port to 9 it will change , switchport access vlan 9 . Are those trunks working currently , usually a trunk will not even show what the access vlan is if the trunk is working. The show vlan command tells you what vlan the port would be in if it was in access mode and not trunk mode.
news2010a Tue, 05/19/2009 - 17:58
Traffic is flowing and I can get to other devices via the trunk.
Hey, is there any implication in doing the 'switchport access vlan x' on a port which is actually on a trunk?
I always thought that or you are in trunk or you are in 'mode access'... that's new to me.
Correct Answer
Giuseppe Larosa Wed, 05/20/2009 - 02:23
  • Hall of Fame,
    Founding Member
Hello Marlon,
Hope to help
Giuseppe
rakesh.hegde Fri, 05/22/2009 - 04:28
As mentioned on your other post below, this is because either gig 0/24 is down or not trunking. It's got nothing to with native vlans. The port is considered to be in administratively configured vlan(vlan 1 if not conigured) if it can not beceome a trunk.
show int gig 0/24 switchport should help
http://forum.cisco.com/eforum/servlet/NetProf;jsessionid=F5FBE89F4279D5CCDB2646773121B968.SJ1B?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&topicID=.ee71a04&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd319f6
-Rakesh
dasmith58 Fri, 05/22/2009 - 09:45
You have to put the interface on the other end of the trunk link in native vlan 9 as well.
