Port Redirection and NAT
mike-greene
Level 4
Level 4
I have a situation where I have a single NAT'ed server that needs ports http, https and a port redirection from 8080 to https done from the Internet into our DMZ. Currently, I have a regular static and ACL that allows http and https traffic. The port redirection piece is the question here because the only way I know how to do this is with a static statement. I already have one static for the http and https traffic so I can't add another for the redirection part.
Is there another way to do port redirection without using statics?
Thanks in advance.
5 Replies 5
CSCO10905906
hi mike,
your question is not very much clear.
hope the below commnand will help you to resolve your issue.
(config)# static (inside,outside) tcp interface or publicip www 192.168.10.10 www netmask 255.255.255.255
(config)# static (inside,outside) tcp interface or publicip https 192.168.10.10 https netmask 255.255.255.255
(config)# static (inside,outside) tcp interface or publicip 8080 192.168.10.20 https netmask 255.255.255.255
rgrds
Naveen
Thanks Naveen,
Thanks for the reply. I need the config to look like this..
static (dmz,outside) tcp 125.x.x.34 www 192.x.x.34 www netmask 255.255.255.255
static (dmz,outside) tcp 125.x.x.34 https 192.x.x.34 https netmask 255.255.255.255
static (dmz,outside) tcp 125.x.x.34 8888 192.x.x.34 https netmask 255.255.255.255
The last static gives me an duplicate error because the static above it allows https already I'm assuming.
Thanks.
Unfortunately it is a dup static entry for https doing it that way using same local host
unless you assign a secondary IP address on the server - 192.x.x.35 as second IP.
But probably best way is to workaround it by using policy NAT.
doing it with secondary server IP eg.. 192.x.x.35 would be as:
static (dmz,outside) tcp 125.x.x.34 8888 192.x.x.35 https netmask 255.255.255.255
Doing it with policy NAT - no need for secondary IP address on server but using same 192.x.x.34 address.
access-list policy_nat1 permit tcp host 192.x.x.34 eq https any
access-list policy_nat2 permit tcp host 192.x.x.34 eq https any
static (dmz,outside) tcp 125.x.x.34 https access-list policy_nat1
static (dmz,outside) tcp 125.x.x.34 8888 access-list policy_nat2
Jorge Rodriguez
Thanks!!
We found out that the server did not need redirection but thanks for the solution for future use.
Thanks Again.
You're welcome Mike, thanks for rating.
Jorge Rodriguez
