CISCO ASA: Unable to connect to DMZ
May 19th, 2009
I have setup a network below:
LAN <==> Cisco ASA) <==> Internet
DMZ
I'm having problem connecting (ping) from Internal to hosts on the DMZ.
My plan is to allow all hosts on Internal to connect (ping) to DMZ. IP Address on Internal should not be natted on DMZ.
And allow some of the host to connect to Internal hosts. No natting also.
Below is my current configuration:
ciscoasa(config)# sh run
: Saved
ASA Version 8.0(2)
hostname ciscoasa
enable password Qe0yKBKYpRMBmOsL encrypted
names
interface Ethernet0/0
nameif external
security-level 0
ip address 116.xyz.xyz.228 255.255.255.192
interface Ethernet0/1
nameif internal
security-level 100
ip address 172.31.24.253 255.255.248.0
interface Ethernet0/2
nameif dmz
security-level 50
ip address 192.168.0.253 255.255.255.0
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
access-list ping extended permit icmp any any echo-reply
access-list ping extended permit icmp any any time-exceeded
access-list ping extended permit icmp any any unreachable
pager lines 24
logging asdm informational
mtu external 1500
mtu internal 1500
mtu management 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (external) 1 interface
nat (internal) 1 0.0.0.0 0.0.0.0
static (internal,dmz) 172.31.0.0 172.31.0.0 netmask 255.255.248.0
access-group ping in interface external
access-group ping in interface dmz
route external 0.0.0.0 0.0.0.0 116.xyz.xyz.193 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:2f8ad3795ba88821b7fd8294ed015999
: end
Sorry, I'm new to cisco and I am eager to learn cisco.
Hope you can help me.
Lonski
mike-greene Tue, 05/19/2009 - 16:58
Does not look like your allowing echo. Try adding this command to your ACL..
lonskinini Tue, 05/19/2009 - 17:12
Hi Mike,
Thanks for the advise.
I have just added the acl but it still giving me same result.
Is there anything I should add with nat or route?
Thanks again.
Lonski
mike-greene Tue, 05/19/2009 - 17:19
Can you post a show access-list. Also can you ping the DMZ and internal hosts from the ASA?
lonskinini Tue, 05/19/2009 - 17:30
Hi Mike,
Here it is:
Ping from ASA to DMZ host (192.168.0.180)
ciscoasa(config-if)# ping 192.168.0.180
Sending 5, 100-byte ICMP Echos to 192.168.0.180, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Ping from ASA to Internal (172.31.26.65)
ciscoasa(config)# ping 172.31.26.65
Sending 5, 100-byte ICMP Echos to 172.31.26.65, timeout is 2 seconds:
Access-list:
ciscoasa(config-if)# show access-list
access-list cached ACL log flows: total 0, denied 0 (deny-flow-max 4096)
alert-interval 300
access-list ping; 4 elements
access-list ping line 1 extended permit icmp any any echo-reply (hitcnt=8) 0x6431b796
access-list ping line 2 extended permit icmp any any time-exceeded (hitcnt=72) 0x406ef9e9
access-list ping line 3 extended permit icmp any any unreachable (hitcnt=17) 0x45fe8bbe
access-list ping line 4 extended permit icmp any any echo (hitcnt=0) 0x931c70e
Hope this helps.
mike-greene Tue, 05/19/2009 - 17:36
Your static looks like it's the wrong subnet. Remove the current static and add this one..
static (internal,dmz) 172.31.24.0 172.31.24.0 netmask 255.255.248.0
lonskinini Tue, 05/19/2009 - 17:58
Hi Mike,
I have replaced the static base from your suggestion but it has still same result.
By the way, this is the range of ip address of the internal:
172.31.24.0 - 172.31.24.255
172.31.25.0 - 172.31.25.255
172.31.26.0 - 172.31.26.255
172.31.27.0 - 172.31.27.255
172.31.28.0 - 172.31.28.255
172.31.29.0 - 172.31.28.255
172.31.30.0 - 172.31.30.255
172.31.31.0 - 172.31.31.255
Hi Mike,
172.31.29.0 - 172.31.29.255
mike-greene Tue, 05/19/2009 - 18:34
OK. What is the default gateway of the machine on the internal network you were able to ping from the ASA (172.31.26.65 )?
IS the ASA the gateway for the DMZ subnet?
lonskinini Tue, 05/19/2009 - 18:50
The default gateway of internal host is the address of ASA on internal(172.31.24.253) and default gateway of DMZ host is also the address of ASA in DMZ (192.168.0.253).
lonskinini Tue, 05/19/2009 - 18:54
Just to add:
I can ping from DMZ host the address of the DMZ gateway (192.168.0.253)
mike-greene Tue, 05/19/2009 - 19:06
Can you issue a clear xlate and try and ping again? Can you also post the running config again.
lonskinini Tue, 05/19/2009 - 19:12
Done clearing xlate... same result :(
Here's the updated config:
: Saved
ASA Version 8.0(2)
hostname ciscoasa
names
nameif external
security-level 0
nameif internal
security-level 100
nameif dmz
security-level 50
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
management-only
ftp mode passive
pager lines 24
mtu external 1500
mtu internal 1500
mtu management 1500
mtu dmz 1500
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
: end
mike-greene Tue, 05/19/2009 - 19:15
Remove the ping ACL from the external interface and apply it to the dmz interface and try again.
no access-group ping in interface external
lonskinini Tue, 05/19/2009 - 19:26
Hi Mike,
I tried removing 'access-group ping in interface external' and the result is it will not let me ping internet (ie. google.com)
I tried issuing 'access-group ping in interface dmz' but still same result. I'm unable to ping from internal to dmz.
mike-greene Tue, 05/19/2009 - 19:54
You can remove this command..
Other then that the config looks ok to me. ... It is late though and it's been a long day.
The only other item I can think of to check tonight is the routing tables on the internal and DMZ systems to make sure there not sending the traffic somewhere else.. I believe the command is route print on a Microsoft box.
lonskinini Tue, 05/19/2009 - 20:54
Hi Mike,
Yeah, it's been a long day.
Just a thought, do we need to change from static to dynamic nat?
I'm not sure, I'm thinking that internal is unable to communicate with dmz because it is from different subnet since we used the static nat. ??? not so sure. =)
lonskinini Wed, 05/20/2009 - 02:10
Hi Mike,
Hope this ICMP log from ASA will help:
FROM INTERNAL
TO Internal Interface: (successful)
ICMP echo request from 172.31.26.65 to 172.31.24.253 ID=1024 seq=18654 len=32
ICMP echo reply from 172.31.24.253 to 172.31.26.65 ID=1024 seq=18654 len=32
TO External (yahoo.com): (successful)
ICMP echo request from internal:172.31.26.65 to external:209.191.93.53 ID=1024 seq=19166 len=32
ICMP echo request translating internal:172.31.26.65/1024 to external:116.50.189.228/5
ICMP echo reply from external:209.191.93.53 to internal:116.xyz.xyz.228 ID=5 seq=19166 len=32
ICMP echo reply untranslating external:116.xyz.xyz.228/5 to internal:172.31.26.65/1024
TO DMZ Interface: (not successful)
ICMP echo request from internal:172.31.26.65 to dmz:192.168.0.253 ID=1024 seq=20190 len=32
ICMP echo request from internal:172.31.26.65 to dmz:192.168.0.253 ID=1024 seq=20446 len=32
ICMP echo request from internal:172.31.26.65 to dmz:192.168.0.253 ID=1024 seq=20702 len=32
TO host on DMZ segment: (not successful)
ICMP echo request from internal:172.31.26.65 to dmz:192.168.0.180 ID=1024 seq=20958 len=32
ICMP echo request from internal:172.31.26.65 to dmz:192.168.0.180 ID=1024 seq=21214 len=32
ICMP echo request from internal:172.31.26.65 to dmz:192.168.0.180 ID=1024 seq=21470 len=32
lonskinini Mon, 05/25/2009 - 18:09
I was able to resolve the issue by adding the following:
nat (internal) 1 192.168.0.0 255.255.255.0
global (dmz) 1 interface
clear arp
clear xlate
clear local
Kureli Sankar Mon, 05/25/2009 - 18:56
You can only ping the closest interface to the client - meaning from an inside host you cannot ping the DMZ interface IP address of the firewall.
With that said,
1. the static looks correct.
2. permission looks correct also.
In fact you can remove this line
and add the inspect icmp
inspect icmp
If the above doesn't work pls. collect the syslogs (while you ping the dmz host continuously) and paste them here.
logging on
logging buffered 7
sh logg | i 172.31.26.65
lonskinini Mon, 05/25/2009 - 19:13
Hi Kusankar,
Actually, it's working already.
I tried removing 'access-group ping in interface dmz' and added 'inspect icmp' and it's working too.
Thanks for your support. I really appreciate it. =)
Lonski
Hi Mike,
