cannot access 4402 controller management IP
I just purchased a wireless controller 4402 and I'm new to using a controller.
I booted it up and I setup the ip address information on it. (management IP, service port IP, AP-management IP).
I'm able to access the device from the CLI thru a serial cable and also if I'm plugged in with a laptop thru the service port.
I am not able to ping or access the device via its management IP address or its service port IP address from any PC on the network.
I tried different settings on the switch port (i.e. trunk, access).
dennischolmes Wed, 05/20/2009 - 02:35
Did you place both the management address and the service port address in the same network? This will cause failure as the service port must be out of band.
weterry Wed, 05/20/2009 - 19:01
Did you set a vlan for your management interface?
Your management vlan should be 0 if the native vlan (or access vlan) is the vlan for the management interface.
Leo Laohoo Wed, 05/20/2009 - 20:08
Taken from Cisco 440X Series Wireless LAN Controllers Deployment Guide
Management Interface
The Management interface is the default interface for in-band management of theWLC and connectivity to enterprise services such as AAA servers. The Management interface is the only consistently "pingable" in-band interface IP address on the WLC.
Service-Port Interface
The service port interface must have an IP address on a different subnet from the Management, AP Manager, and any dynamic interfaces. The service port can get an IP address via DHCP or it can be assigned a static IP address, but a default-gateway cannot be assigned to the Service-port interface. The Service-port is typically
reserved for out-of-band management in the event of a network failure. It is also the only port that is active when the controller is in boot mode.
Hope this helps. Please rate when applicable.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
