how to write document to mapping disc
May 19th, 2009
I have UCCX 5.0.2.
When off duty,caller can live a record.UCCX can record the message to local disc,however it can't record to a mapping disc.
I use the command "G: \\IP\ciscorec "pass" /user:account" to mapping a disc.
When testing the record,I hear the prompt that something is wrong with the system.
markjiang Tue, 05/19/2009 - 21:09
I use write document step to write the record in disc.
Jonathan Schulenberg Thu, 05/21/2009 - 13:29
  • Cisco Designated VIP,
    2017 IP Telephony
This is not going to work as Tomcat is not logged in as a user to use a CIFS share. More importantly, I would strongly recommend against designing anything that writes directly to the local hard disk. You will no longer have access to it starting in version 8.0 as the product is moving to Linux.
If you are recording a file and want to send it to someone, you should be using the Email steps to send SMTP mail. Note this requires premium licensing.
Alternatively you can experiment with using the "message in queue" concept but I would use caution if you are not very familiar with the CCX scripting engine as this can have negative consequences if done poorly. Search the forum, there are many postings on this.
markjiang Thu, 05/21/2009 - 21:15
Thanks, j.schulenberg.
I will test the "message in queue".
