port forwarding to the broadcast address.
May 19th, 2009
I am trying to setup a Wake On Lan machine in my home network.
If I am home and send a wol packet to the broadcast address then my computer wakes up... However I am at work and send the wol packet to my router I need my router to port forward that packet to the broadcast address... UDP...
However my linksys wrt600N won't let me set the port forward from port 9 to 9 onto ip address 192.168.1.255.. It says I need to enter something between 1 and 254...
How can I port forward to a broadcast address? Is there a reason I shouldn't?
hobbe Fri, 05/22/2009 - 03:58
most likely this is blocked to prevent a smurf attack (accidental or otherwise) or you to be a amplifier in a attack or something similar.
what you can do is to use a machine locally on that network that you have the wake on lan software on and to remotely access it.
I do not know if this is good enough solution for you. there are several other ways of doing it but they all include buying hardware at a not so small cost.
openipltd Fri, 05/22/2009 - 04:09
dd-wrt has a WOL client built in and will work on a WRT600N.
