CCIE Voice LAB using VMware and GNS3
May 19th, 2009
Dear all,
I would be very pleased if anybody can tell me how i can stimulate a decent CCIE Voice lab using VMware and GNS3.
I have a desktop with core 2 quard processor and 4GB ram. I have installed VMware and i m running CUCM 6.1 on it as well i have installed GNS3.
I need to know how i can best utilize both these application to practice for CCIE Voice lab. Please note that i have a CCME router 3825+Ip Phones+CiscoPoE Switch running in my network.
Any kind of link and support from you will highly be commendable.
Malik.
Overall Rating: 5 (4 ratings)
Justin Brenton Wed, 05/20/2009 - 02:38
  • Silver, 250 points or more
Hi Malik,
You can use the 1 pc for all both the CUCM image and GNS3 with the ram that you have...
Now if you plan on installing Unity, Presence, IPCC, etc I would then suggest dedicating this machine to VMWare images and having another maching run your gns3 routers. \
Place both machines in the same network.
I personally have a pc for my vmware images (CUCM, UNITY, PRESENCE, IPCC) running on linux and I have a laptop that I use for GNS3 and use for my IP Communicator, Personal Communicator, etc.
hth, plz rate
Justin
tiger_401 Wed, 05/20/2009 - 06:03
Hi Justin,
Really appreciate your response. But boss i need to know how i can setup the lab. I have my laptop as well,on which i can run GNS3. Can you please send me some link which will help me setting up a basic lab for CCIE Voice.
Malik.
