05-19-2009 11:29 PM - edited 02-21-2020 04:14 PM
I have an existing L2L VPN setup with a Cisco 3030 and a Cisco 3620. It has been working fine for the last few weeks.
A few days ago, the tunnel dropped and now I only see traffic in one direction. There's no error messages in debug on either routers and I'm not sure where to go from here.
I can see the VPN establish, Phase 2 is completed on both sides.
I can see traffic leave the 3030 but I never get anything back from the 3620.
Doing a packet capture on the 3620 I see no IPsec packets leave the router to the 3030, it is simply not tunneling the traffic.
"Network lists" on both devices are set the same, networks:
10.0.0.0/0.255.255.255
172.16.0.0/0.15.255.255
and
192.168.5.0/0.0.0.255
There is no firewall in front of the 3620, packets are simply not leaving the router.
The 3620 has a single interface, it is a "router on a stick", I'm not sure if this could be causing any issues.
I've attached the 3620 config.
Anyone has any idea?
Thanks!
Jonathan.
05-20-2009 08:39 AM
Are the packets you don't see being returned initiated from the concentrator or a device behind the concentrator?
Any NAT going on?
05-21-2009 07:10 PM
Thanks for the reply - Turns out one end of the VPN was behind NAT, NAT-T was turned on the 3030 and the issue went away.
Not sure how this worked for a few weeks without NAT-T.
It's all good now, cheers!
05-26-2009 04:26 AM
Excellent! NAT-T can be one of those little things that frequently get's over looked.
This is a really good document for understanding the steps (order of operation).
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080133ddd.shtml
HTH,
-Brandon
