Console time out
May 20th, 2009
Hi, what is the meaning of following timer
Line Console 0
Absolute-timeout 0
smothuku Wed, 05/20/2009 - 00:16
Hi Rupesh ,
To set the interval for closing the connection, use the absolute-timeout command in line configuration mode. To restore the default, use the no form of this command.
absolute-timeout minutes
no absolute-timeout
The following example sets an interval of 60 minutes on line 5:
line 5
absolute-timeout 60
Related Commands
Command Description
Sets the interval that the EXEC command interpreter waits until user input is detected.
Sets and displays a warning for users about an impending forced timeout.
Sets the interval for closing the connection on a console or terminal line.
smothuku Wed, 05/20/2009 - 00:18
Hi Rupesh ,
Use the absolute-timeout command line configuration command to configure the EXEC to terminate when the configured number of minutes occurs on the virtual terminal (vty) line. The absolute-timeout command terminates the connection after the specified time period has elapsed, regardless of whether the connection is being used at the time of termination. You can specify an absolute-timeout value for each port. The user is given 20 seconds notice before the session is terminated. You can use this command along with the logout-warning command to notify users of an impending logout.
Cisco IOS software also provides the session-timeout and exec-timeout line configuration commands for releasing lines when they have been idle for too long.
You can set the absolute-timeout command and an AppleTalk Remote Access Protocol (ARAP) timeout for the same line; however, this command supersedes any timeouts set in ARAP. Additionally, ARAP users will receive no notice of any impending termination if you use this command.
Cheers ,
Rupesh Kashyap Wed, 05/20/2009 - 00:30
Thanks. What should I do , If I want Absolute timer as Infinitive ? Should I mark as zero or any other figure ?
