How to send caller id for certain numbers
May 20th, 2009
I am running a call manager express system and the client would like to send caller id when dialling certain numbers but restrict CLID when dialling others. I have a fractional E1 to the PSTN for incoming and outgoing calls.
I was thinking of doing this on the dial peer by using a prefix code and then stripping it using a translation rule and enabling/disabling the clid eg.
Dial-peer voice 10 pots
destination pattern 9888T
translation-profile outgoing
clid enable
So therefore if the client wanted to show their clid when making an outgoing call they would dial 9888 (which will get stripped by the translation rule) and their clid would be displayed.
If they did not want it displayed they would dial as normal.
Am i on the right track here or is there a better way of doing this ?
paolo bevilacqua Wed, 05/20/2009 - 12:14
  • Hall of Fame,
    Founding Member
Yes there is a better way. Under telephony-service define caller-id block code, e.g. *67.
Router will translate that to the appropriate q931 parameter, making the call from a private party.
