Port FWD
May 20th, 2009
Hello all.
I'm sure I'm missing something...but I can not understand what...
I have a port redirection problem. I have a CISCO router configured as shown in the conf file below.
I'm trying to configure a port forward to an internal server on port 1723 with the following command:
ip nat inside source static tcp 192.168.5.11 1723 interface Serial2/0 1723
the command is accepted without error, but the port redirection does not work. I tried to add
a "permit tcp any any" but no luck.
Any ideas about what I'm doing wrong?
Cips
version 12.4
service password-encryption
hostname c1841
boot-start-marker
boot-end-marker
enable secret
no aaa new-model
ip cef
no ip domain lookup
crypto isakmp policy 100
encr 3des
authentication pre-share
group 2
crypto isakmp key key1234 address xx.xx.46.241
crypto ipsec transform-set key1234 esp-3des esp-sha-hmac
crypto ipsec profile key1234
set transform-set key1234
interface Loopback10
ip address xx.xx.243.53 255.255.255.255
interface Loopback11
ip address xx.xx.243.54 255.255.255.255
interface Tunnel10
description VPN-->OUT
ip address 10.0.0.2 255.255.255.252
tunnel source Loopback11
tunnel destination xx.xx.46.241
tunnel mode ipsec ipv4
tunnel protection ipsec profile key1234
interface FastEthernet0/0
ip address 192.168.5.250 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial2/0
ip address xx.xx.246.222 255.255.255.252
ip nat outside
encapsulation frame-relay IETF
frame-relay map ip xx.xx.246.221 20 broadcast IETF
no frame-relay inverse-arp
ip route 0.0.0.0 0.0.0.0 Serial2/0 xx.xx.246.221
ip route 192.168.0.0 255.255.255.0 Tunnel10
ip http server
no ip http secure-server
ip nat pool internet xx.xx.243.49 xx.xx.243.50 netmask 255.255.255.252
ip nat inside source list nat pool internet overload
ip access-list extended nat
deny ip 192.168.5.0 0.0.0.255 192.168.0.0 0.0.0.255
permit ip 192.168.5.0 0.0.0.255 any
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
logging synchronous
login
scheduler allocate 20000 1000
end
Brian Meade Wed, 05/20/2009 - 07:44
  • Silver, 250 points or more
So it looks like you're trying to forward TCP port 1723 from an internal IP address to an outside interface, is this correct?
If so, you should use this command:
ip nat outside source static tcp 192.168.5.11 1723 interface Serial2/0 1723
If you're trying to forward that part from the outside interface to the internal IP address which sounds more probable, you're command should be:
ip nat inside source static tcp interface Serial2/0 1723 192.168.5.11 1723
Brian Meade Wed, 05/20/2009 - 07:50
Actually here is the command for Situation B:
#ip nat outside source static tcp xx.xx.246.222 1723 192.168.5.11 1723
ciscocips Thu, 05/21/2009 - 01:17
Thanks so much for the reply.
I'm actually trying to redirect from external interface the port 1723 on an internal server. All the samples I found were using "ip nat inside"....but probably I did not read the sample carefully enough.
Brian Meade Thu, 05/21/2009 - 06:47
No problem, I think I may have messed up when specifying inside and outside. For your situation, this would be the appropriate command:
ip nat inside source static tcp xx.xx.246.222 1723 192.168.5.11 1723
