webVPN problems
May 20th, 2009
Hi.
At my institution there are two CVPN 3000 systems. One is used for VPN connections and the other for WebVPN sessions. We're doing this because the WebVPN service sometimes hangs without a valid reason and stops responding to pings or session attempts. So we decided to separate the two services.
It's the 3rd time this year that our WebVPN cvpn hangs. But this time we've managed to gather some logs. These are some lines:
_______________________
16278 05/18/2009 22:30:26.150 SEV=2 HTTP/21 RPT=69 a.b.c.d
HTTP 500 No Resources
16305 05/18/2009 22:30:57.840 SEV=4 HTTP/50 RPT=6264 a.b.c.d
HTTP 404 Not Found (/scidirimg/sci_dir/navbar_select.gif)
16335 05/18/2009 22:32:48.900 SEV=5 SMTP/17 RPT=55
SMTP Greeting Error:
16584 05/18/2009 22:39:39.220 SEV=4 HTTP/37 RPT=663
Closing socket 5 for invalid connection 0xE57354C.
I've discovered some warnings too:
SEV=3 CAPI/1 RPT=2 CAPI - Error!!!, HW Crypto Command 0x1c to SEP Slot #2 failed with status 0x9
After these errors, only a reboot solved the problem.
Some details of our CVPN:
VPN Concentrator Type: 3060
Bootcode Rev: Cisco Systems, Inc./VPN 3000 Concentrator Series Version 4.0.Rel Mar 25 2003 15:45:12
Software Rev: Cisco Systems, Inc./VPN 3000 Concentrator Version 4.7.2.P Jul 30 2008 15:10:24
RAM Size: 384 MB (Memory Status: Green)
The problem appeared before the upgrade to version 4.7.2.P and continued to appear afterwards.
If someone could help it would be appreciated.
Jose
