Router 2811
May 20th, 2009
I have a problem with cisco 2811 router. For 7 days it worked fine, but after this period I had to restart to force them to work propertly.
I suspect that RAM memory has a problem, but I cann't find memory test command.
Ios version is: 12.4(13r)T
c2800nm-adventerprisek9-mz.124-22.T.bin
Only existed test commands are:
Router#test ?
Virtual-Template Virtual Template interface
aaa AAA Authentication, Authorization and Accounting
appletalk APPLETALK diagnostic code
arp_retry Test ARP Retry
atm ATM test commands
cac test the l2 cac functionality
call Call test commands
cch323 cch323 tests
cef Cisco Express Forwarding test command
cfmpal CFM test commands
checkpoint checkpoint test commands
cns CNS agents
corrupt-nvram Corrupt NVRAM Magic
cpurmi CPU RMI test commands
crypto Test crypto functions
dot11 IEEE 802.11 test command
dsp Test DSP functions
enum test enum
firewall Test firewall functions
glbp Gateway Load Balancing Protocol test commands
gsi Test gsi
gssapi GSSAPI test code
gt96k Test gt96k timer System
hpi host port interface
ifs IFS TEST code
interfaces Network interfaces
iphc IPHC testing
ipmobile IP Mobility Test commands
lic-agent lic-agent test command
license Test License command
license-parser Test License Parser
lmr Diagnose lmr ports with simulating dsp event
mpls MPLS test commands
oer Test Optimized Edge Routing (OER)
opssl OPSSL Test
ospfv3 OSPFv3 Test options
pasvc PPP over ATM SVC Test Driver
pppatm PPP over ATM SSS Test
pppoe PPPoE test commands
process Create/kill test processes
rtcp Test RTCP SSM
sasl Test SASL code.
save save load monitor snapshot
scp SCP test commands
sctp SCTP test commands
sgbp SGBP test commands
source-group Test Source IP Group
spanning-tree Spanning Tree Subsystem
srtp Test SRTP Libray functionality
ssm SSM test commands
stun STUN Stack test command
sw-vlan Test VLAN Manager feature
tar test tar file system
tdm Test TDM
tms TMS related test commands
token TOKEN Interface
tpu TPU test system
track Object Tracking test commands
translate Protocol translation test function
translation-rule Test translation rule table
trunkgroup Test trunk group
tunnel Test tunnel
urlf Url Filtering
usb USB Interface
voice Voice related test commands
voip-aaa voip-aaa test menu utility
How I can test memory in this case?
Best regards,
Miroslav Petkovic
Overall Rating: 5 (3 ratings)
Paolo Bevilacqua Wed, 05/20/2009 - 06:18
Most often router freeze is due to IOS bugs.
You can either connect to console when it freezes to tr to find what's going on, or possibly downgrade IOS in search of a stable image.
pjeunelot Wed, 05/20/2009 - 13:53
I would start with checking to see if you have the required memory for the IOS version you are using by doing a show version. This will also tell you if your router is recognising the that is installed. It should match the amount that you ordered with your router.
You can also check to see if you IOS is corrupt by using the verify command.
http://www.cisco.com/en/US/docs/ios/12_0/configfun/command/reference/frifs.html#wp1018734
Another thing to do is to boot the router with a terminal emulator connected to the console so you can watch for errors upon booting. If you have a problem with memory it may show here.
I could not find the test memory in my 2811 either so it must have been removed or not be supported on this model router. It is however in the Command lookup tool under 12.4 IOS so the command should exist.
Hope this helps.
miroslavpetkovic Thu, 05/21/2009 - 00:13
Thank you for this informations.
I didn't notice error message in process of booting router which I monitored by console connection and Hyper Terminal.
I added attachments:
- system boot
- sh version
- verify IOS
If you notice something suspiciously please send me message.
BR,
Miroslav Petkovic
Joseph W. Doherty Thu, 05/21/2009 - 02:36
Like Paolo, I too suspect an IOS in such cases, assuming the hardware isn't faulty. In your case, your 2821 is running a recent "T" version but there are a couple of newer versions, including a newer one for the version you're running, 12.4.22T1. You might upgrade, or downgrade to a version of 12.4, which might be a little more stable, if you don't need a feature in the "T" versions. Also, you could update your ROM software, which notes "DRAM access optimization" in the latest.
pjeunelot Thu, 05/21/2009 - 09:11
I agree if you suspect the IOS then upgrading it might solve your problem so you can try the update 12.4.24 that is out. It may be a bug with one of the features you are using which is hard to tell with the info posted. You may want to check the bug tracking system to see if your specific problem has been reported.
http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
