Install demo license ANM 2.0
May 20th, 2009
Hi all,
After installation of ANM 2.0 and got a demo license I don't know how to install it. The path /opt/CSCOcbt/httpServer/webapps/ROOT/WEB-INF/classes/lic does not exist, and the install program /opt/CSCOanm/bin/anm-license gives error: Error: MAC address of license does not match MAC address of eth0.
Is there someone out there who has a clue?
Thanks Alf
dario.didio Thu, 05/21/2009 - 01:03
Did you enter the correct MAC address of ETH0 when requesting the demo license?
"Please enter below the 12 digits of the MAC address of Ethernet Interface 0 (eth0) of the server hardware on which you will be installing your Cisco Application Networking Manager software. The following command can be executed on your server to provide you with the required information.
command> /sbin/ifconfig eth0 | grep -i hwaddr | sed 's/://g'
response> eth0 Link encapEthernet HWaddr 00C09F6063D0
In the above example, the required MAC address to enter here is:00C09F6063D0"
If this is not correct, you should open a ticket
Here is the procedure to install the license:
http://www.cisco.com/en/US/docs/net_mgmt/application_networking_manager/2.0/installation/guide/IG_config.html#wp1084390
There is a link to the Cisco TAC in case you want to request a new license due to problems.
Here is the procedure how to install ANM.
http://www.cisco.com/en/US/docs/net_mgmt/application_networking_manager/2.0/installation/guide/IG_install.html#wp1069131
HTH,
Dario
acarlsson Fri, 05/22/2009 - 01:12
I am the problem! I did'nt chose the correct license-file. After downloading +install the correct file, and reload of the server, the problem is solved. Sorry to bother you!
Thanks Alf
