I try to delete the flash /force, but it errors out. How can I delete it?
Answered Question
May 20th, 2009
I noticed that it states the respective flash I want to delete is 'a directory'. Do you know the syntax to delete it then? I tried to use the one below but it does not work.
Directory of flash:/
2 -rwx 736 Mar 16 1993 00:44:01 +00:00 vlan.dat
3 -rwx 1915 Mar 1 1993 14:27:30 +00:00 private-config.text
4 -rwx 4272 Mar 1 1993 14:27:30 +00:00 config.text
5 -rwx 8055039 Mar 1 1993 00:15:46 +00:00 c2960-lanbasek9-mz.122-50. SE1.bin
6 -rwx 2072 Mar 1 1993 14:27:30 +00:00 multiple-fs
7 drwx 192 Mar 1 1993 00:06:55 +00:00 c2960-lanbase-mz.122-35.SE 5
32514048 bytes total (16114176 bytes free)
sw1#del /force flash:c2960-lanbase-mz.122-35.SE5
%Error deleting flash:c2960-lanbase-mz.122-35.SE5 (Is a directory)
Correct Answer by jpoplawski about 7 years 10 months ago
Try this:
del /f /r flash:/c2960-lanbase-mz.122-35.SE5
Typically when I get a box, I del /r /f flash:* and then upload the latest image.
Hope this helps, rate if it does.
JB
Overall Rating: 5 (1 ratings)
Correct Answer
jpoplawski Wed, 05/20/2009 - 07:37
  • Bronze, 100 points or more
Try this:
JB
Try this:
JB
