********************Calls disconnected Cause*******************
May 20th, 2009
Hi Pros,
My voice gw displays this :
Successful Calls = 0, Failed Calls = 6, Incomplete Calls = 0
Accepted Calls = 0, Refused Calls = 0,
Last Disconnect Cause is "39 "
That is 39 means.
Looked on cisco web site,I could not find a doc that explains the cause. Can one of you point that explains all the cause of a call failing.
Thanks in advance,
Crazy
CrazyDonJuan Wed, 05/20/2009 - 08:53
doc says: 39 means Permanent frame mode connection is out of service.
What does that means?
Sorry bor my silly question.
Crazy
paolo bevilacqua Wed, 05/20/2009 - 08:57
  • Hall of Fame,
    Founding Member
Do the actual call with the appropriate debugs.
That will be more informative that the output above.
