802.11n
May 20th, 2009
Hi NetPros,
Small question as the new Cisco 5508 Wireless Controllers is out in the market which works on 802.11n technology, so how it is different from any 802.11g WLC in compare to speed,non overlapping channel and security point of view.
Prasad
Overall Rating: 3.5 (2 ratings)
dancampb Wed, 05/20/2009 - 08:56
  • Cisco Employee,
The 5508 has 8 gigabit port that can be put into a LAG bundle compared to the 2 or 4 that were available in the 4400's. The hardware architecture also has been changed to provide faster processing of packets through the controller.
Manish Prasad Wed, 05/20/2009 - 09:15
Thank You Dan
"Delivers more efficient roaming, with at least nine times the throughput of existing 802.11a/g networks" can you explain its meaning.
Robert.N.Barrett_2 Wed, 05/20/2009 - 09:23
  • Bronze, 100 points or more
My understanding is that it can also simultaenously join/upgrade up to 100 APs at a time (4400's will handle 10 and current WiSMs handle 20, I think)
JASON BOYERS Wed, 05/20/2009 - 18:54
Existing controllers (440x, 21xx, WiSM, etc) running v4.2 or greater already support 802.11n, as they support the 1252 access points. Also, non-overlapping channels does not change for 802.11n - it uses the same channels as 802.11a/b/g. Security options for wireless clients remain the same, from what I am seeing.
The big thing for speed, as was alluded to earlier, is that with 8 SFP ports, you can set up link aggregation to use up to 8Gbps.
Matthew Fowler Wed, 05/20/2009 - 23:07
  • Cisco Employee,
The more efficient roaming is due to the fact you can now have 250 APs on the one controller, which means you can reduce inter-controller roaming.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
