05-20-2009 08:44 AM - edited 03-09-2019 10:18 PM
Hi all,
Is it possible to have 2 tacacs server on same network, if the first server auth fail,
then, the second one will do the auth ?
Solved! Go to Solution.
05-20-2009 08:56 AM
Sure is. Just configure your network devices to fail over to the alternate server if the first is unavailable.
05-22-2009 01:47 AM
If you use ACS as your tacacs server, you can synchronize the user databases between the multiple tacacs servers.
If you don't synchronize them then you can have the same username with different passwords/policies on the different ACS boxes. It's all a matter of how you configure your boxes, with synchronization or not.
05-20-2009 08:56 AM
05-21-2009 04:37 PM
Thanks for your answer .
So can two tacacs sever have different
user name ? for example,
Tacacs server A, user A = Adam
Tacacs server B, user B = Adam
please note that user A and user B are different person.
Will there be a sync issues, if it is ?
05-22-2009 01:47 AM
