Multilink Errors and Reliability
May 20th, 2009
I have 3 Serial interfaces setup in a multilink configuration. The Multilink interface receive a packet error for almost every input packet. The CRC error counts are almost the same count also. I've checked each individual Serial interface and they show NO errors.
In addition, my Multilink interface availability is constantly 128/255. I will post run-configs and interface status. Thanks in advance for any help.
Paolo Bevilacqua Wed, 05/20/2009 - 13:27
  • Hall of Fame,
    Founding Member
Which exact IOS are you running ?
zebranutz80 Wed, 05/20/2009 - 13:33
c3660-is-mz.123-23.bin
Also...I was researching and Cisco's Output Interpreter said that timing could be a problem. Below is the status of the 3 T1 controllers:
Cisco3660-2#show control T1 1/0
T1 1/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
Description: MPLS Circuit 1
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
Data in current interval (476 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Cisco3660-2#show control T1 1/1
T1 1/1 is up.
Description: MPLS Circuit 2
No alarms detected.
Data in current interval (511 seconds elapsed):
Cisco3660-2#show control T1 2/0
T1 2/0 is up.
Description: MPLS Circuit 3
No alarms detected.
Data in current interval (526 seconds elapsed):
Paolo Bevilacqua Wed, 05/20/2009 - 13:53
  • Hall of Fame,
    Founding Member
All seems fine.
Can you try, for example, 12.4(3j) ?
zebranutz80 Thu, 05/21/2009 - 05:37
Unfortunately no. The router is an old 3660 and would need a memory upgrade first.
