Cisco 524SG Handset Registration Following Reboot of UC520
exonetinf1nity
Greetings, can i ask if anyone has had a similar to me when deploying the UC520 (All Versions 8 - 64 User)
I have noticed that when running IOS v12.4(20)T2 (CME Version 7.0(0)) in combination with 524SG handsets and following a cold reboot of the appliance the 524SG handsets fail to re-register and require manually power off then on again either by pulling the ethernet cable out the back of the phone or shutting down the appropriate switchport and enabling it once again.
Actual performance of the handset isnt impaired once registered however i am interested to know if anyone has experienced a similar issue, i have tested this on the the following models:
  • UC520-8U-2BRI-K9
  • UC520W-8U-2BRI-K9
  • UC520-16U-2BRI-K9
Mark Rigby
Hi Mark,
We just announced the availability of a new CCA and new software packs. The 521-524 load in this packs is 8.1.16b. Please try to upgrade to that version and let us know if you still see issues.
More info on:
https://www.myciscocommunity.com/docs/DOC-7157
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
Hi Mark,
We do not have a manufacturing release (full UC500 Software Pack) with that IOS yet. It will be posted soon. The reason why this is important is that the 521 and 524 phones have only been tested with a new firmware (not publicly available) on that IOS. Other permutations are not tested.
Having said that, let's start by verifying that you are at least running the latest software load on your CP-500 phone. Can you provide a "show ephone phone-load" ?
Marcos Hernandez
Cisco Systems, Inc.
Thank you for your reply, i must admit im somewhat confussed as i can download the latest software pack that includes the IOS mentioned above. Please see the following image from both the download page and the attatched JPG.
Select a File to Download
Sort by :
UC520-7.0.2.zip
UC520 - Complete Software Pack with all components
7.0(2)23-FEB-2009234933703
For your referance please see the results of the  "show ephone phone-load" command.
DeviceName        CurrentPhoneload       PreviousPhoneload      LastReset
SEP0021A02E6265    SCCP41.8-3-5S          SCCP41.8-3-5S         Reset-Reset
SEP00211BFC92EF   8.1.13                 8.1.13                           Hard+CMERequest
SEP00211BFC92F5   8.1.13                 8.1.13                           Hard+CMERequest
SEP00211BFC92F0   8.1.13                 8.1.13                           Hard+CMERequest
SEP00211BFC92ED   8.1.13                 8.1.13                           Hard+Unknown
SEP00211BFC92EE   8.1.13                 8.1.13                           Hard+Unknown
SEP00211BFC92F1   8.1.13                 8.1.13                           Hard+CMERequest
SEP00211BFC92F4   8.1.13                 8.1.13                           Hard+CMERequest
SEP001A4B8451E9    7.0.2.0                7.0.2.0                         Initialized
Hi Mark,
More info on:
Marcos Hernandez
Cisco Systems, Inc.
Thank you for your help Marcos, do you know when the new phone loads will be avaliable for download on Cisco.com?
Edit: Found it on the community website, thank you for your help Marcos.
