Difference between CUCM 7.x and CUCM Express
moabdallah
What are the features difference between CUCM 7.x and CUCM Express ?
Jaime Valencia
There are far too many for a post, read all this
Cisco Unified Communications Manager Version 7.0
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/data_sheet_c78-485333.html
Cisco Unified Communications Manager 7.0
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/solution_overview_c22-493511.html
Cisco Unified Communications Manager Express 7.0
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps4625/data_sheet__c78-484777.html
Cisco Unified CME 7.0/4.3 Supported Firmware, Platforms, Memory, and Voice Products
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme43spc.htm
If you need more info you can read the SRND, refer to integration guides, compatibility guides, etc. All available if you search CCO
java
if this helps, please rate
java
Is there is a feature comparison document between CUCM 7.0 and CUCME 7.0 ?
There isn't one, if you want to compare you'll have to read the docs i provided
java
java
