cat 6500 questions
May 20th, 2009
Hi all
when I boot a cat6500, do both cpu's boot at the same time?
can i console to each of them?
is it possible to telnet from the active card to the standby?
if I was to reload the active card, would it automatically fail to the other card ?
billzha Sat, 05/23/2009 - 15:46
  • Cisco Employee,
Yes.
Yes.
No. But you can check the disk on the standby and use the interfaces as other LAN card.
Yes.
