05-20-2009 06:26 PM - edited 03-11-2019 08:34 AM
Hi Expert,
I have a requirement which asks for tunneling all traffic from vpn client except for 3 public IP addresses. The Client VPN terminates on ASA 5510 version 7.2(4)
The configuration I tried are as below:
access-list exclude_1 extended permit ip 10.24.30.0 255.255.255.0 host 202.3.10.210
access-list exclude_1 extended permit ip 10.24.30.0 255.255.255.0 host 202.3.10.222
access-list exclude_1 extended permit ip 10.24.30.0 255.255.255.0 host 203.2.190.222
group-policy BartterPolicy attributes
wins-server value 10.1.0.63 10.3.0.1
dns-server value 10.1.0.63 10.3.0.1
vpn-tunnel-protocol IPSec
split-tunnel-policy excludespecified
split-tunnel-network-list value exclude_1
but from the stats - route details it stills shows 0.0.0.0 in the secure routes which means tunnel all traffic.
Any idea why this is happening. Thanks in advance.
05-21-2009 03:35 AM
What version of code are you running?
try a different approach:-
split-tunnel-policy tunnelspecified
access-list exclude_1 extended deny ip 10.24.30.0 255.255.255.0 host 202.3.10.210
access-list exclude_1 extended deny ip 10.24.30.0 255.255.255.0 host 202.3.10.222
access-list exclude_1 extended deny ip 10.24.30.0 255.255.255.0 host 203.2.190.222
access-list exclude_1 extended permit ip 10.24.30.0 255.255.255.0 any
HTH>
05-21-2009 07:34 PM
No luck. with this all internal access is not working but Internet access works with any restriction.
05-21-2009 10:34 PM
post the relevant config for review.
06-04-2009 11:07 AM
the checkbox on the client for allow local lan needs to be checked.
06-09-2009 12:29 PM
Under splittunneling access list try adding the IP of the gateway on the remote client side
Also enable split dns
