Exporting the translation patterns and route patterns from CCM
Answered Question
May 20th, 2009
We are still using CCM v4. ;-) Is there a way to export the list of translation patterns and route patterns, including its configuration details?
Thanks!
Correct Answer by nesharm2 about 7 years 8 months ago
Go to Route Plan---->Route plan report
Click on find button with out any thing in the box (this will give you all route patterns etc) On the top right of the page you should see "view in file" where you can save it in a csv/excel file.
Neeraj
Overall Rating: 5 (1 ratings)
Correct Answer
nesharm2 Wed, 05/20/2009 - 23:09
Neeraj
j.huizinga Wed, 05/20/2009 - 23:29
Next step: import a route plan.
Callmanager 8 or 9 maybe version 10?
ladycroft Thu, 05/21/2009 - 00:10
thanks a lot for your help! and thanks to those who also replied. Its just now, we are still using version 4, so no option to export. Only thing i can do is to use 'View in file' and save it to excel.
