Copy one port from another...
May 20th, 2009
Dear experts,
Is there a way to copy one port config to other port ? i mean seemthing like "copy port X to port Y".. That way the machine will copy the whole config of port X one by one to port Y.
Yosi :)
Jon Marshall Thu, 05/21/2009 - 02:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Yosi
You could look into smartport macros which allow you to apply a standard configuration across multiple ports -
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_20_ea2/configuration/guide/swmacro.html#wp1160524
Another option is to use the interface range command eg.
switch(config)# interface range fa0/1 - 10
switch(config-if-range)#
then any commands you type in apply to all ports in the range fa0/1 - 10.
Finally there is good old cut and paste at the CLI prompt.
Jon
Leo Laohoo Thu, 05/21/2009 - 14:38
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Hi Yosi,
Jon's right. I'm using macro and it's alot faster and more accurate than cut-n-paste.
macro apply $tags
Hope this helps. Please rate when applicable.
