Ciscoworks and SSH
May 20th, 2009
we are using Ciscoworks. we want to enable SSH access on all Cisco Network devices. With the help of Ciscoworks Can i generate the report about the Device SSH compatibility? (Resource Manager Essentials 3.5)
Thank you
Vijay K
From my experience, I would say no. I am in the process of doing this for my company. We use Ciscoworks RME 2.6.
I created an inventory report with relevant information:
Hostname
Model
DRAM
FLASH
Current software version
Current software image
Those are the base items you will need. I exported that report to excel and then added my own fields:
Supports SSHv1
Supports SSHv2
SSH Image
SSH Image DRAM requirement
SSH Image FLASH requirement
Then used the IOS feature navigator to find an image that would support SSH.
