Can I make a test VOIP call from Router CMD line
May 20th, 2009
I had a problem with my voip config,after some good advice from this forum I have made some change to the config.
are there any commands i can use to make a test voip call between the routers, so i can check if the new config works.
nesharm2 Wed, 05/20/2009 - 22:56
  • Bronze, 100 points or more
try
csim start #####
Nicholas Matthews Thu, 05/21/2009 - 05:29
  • Red, 2250 points or more
csim start is a legacy command, and I find it only works well for pots test calls. The router doesn't have this capability, but csim start is the only command.
-nick
