05-20-2009 11:29 PM
Dear all,
I will really appreciate your advices regarding the following problem:
I cannot establish a VPN connection using Cisco VPN Client software. The error I get is:
"Secure VPN Connection terminated locally by the Client.
Reason 412: The remote peer is no longer responding."
A TCP connection can be established (please see attached log), but then something goes wrong...
I have a Windows PC. Cisco VPN Client version 4.8.02.0010.
Firewall is disabled. To connect to inrenet, I use Dial-up with a USB modem (just a public internet provider). All other LAN/WLAN Windows connections are disabled, only the Dial-up one is enabled.
In VPN Client software, to connect I use an imported profile for TCP tunnel. The profile is 100% all right - it works by other colleagues, but they connect to internet another way.
Thanks a lot for ANY help!
05-27-2009 05:49 AM
Enable NAT-T in the head end VPN device in order to resolve this error.
05-27-2009 06:59 AM
This can be caused by one or more of these issues.
The host name or IP address of the remote server configured in the VPN client is incorrect.
The group name and password configured in the VPN Client does not match with the group name and password on the headend device. The group name and password are case-sensitive; these can have been typed incorrectly.
The VPN Client does not have IP connectivity to the remote server, or traffic is blocked by a device between the client and the remote server.
Resolution
Complete these steps in order to resolve this issue:
Verify that the hostname or IP address for the remote server configured in the client is correct.
Verify the group name and password configured on VPN client. Right-click Connection entry > Modify > authentication tab in order to do this. These must match with the group name and password configured on the remote server.
Ping the IP address of the remove server in order to verify that the VPN Client device has IP connectivity to the remote server.
Check to see that Internet Key Exchange (IKE) or IPsec traffic is not blocked by a device between the VPN Client and the remote server .
If all above is correct I would upgrade the VPN client software to a later version.
Regards MJ
08-21-2015 05:07 AM
Hello All,
I had a similar problem with Cisco VPN client Version 5.0.07.0290 on Windows 8.1 64-bit.
It gave a popup as mentioned above. I solved the issue by first
Disabling Internet Connection Sharing service
Press Window + R to open run command
Type in services.msc and press enter or OK
Search for Internet Connection Sharing service, stop the service and right on it and disable it.
After this you need to make registry changes
1. Open Registry editor regedit in Run prompt
2. Browse to the Registry Key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\CVirtA
3. Select (double Click) the Display Name to modify, and remove the leading characters from the value data value as shown below:
i.) Below is the value for Display name:
"@oem8.inf,%CVirtA_Desc%;Cisco Systems VPN Adapter for 64-bit Windows”
ii.) Change it to the following by removing the leading characters from the Value -->
"Cisco Systems VPN Adapter for 64-bit Windows"
Thanks.
