Cat 3550 multiple crashes
May 21st, 2009
Hi everybody,
I encountered many crashes during only short time period. I'm using Cat 3550 and there was more than 5 crashes during only few weeks.
Do a high CPU load for about 80 percent can be the cause? Loops?
Energy is well managed as the sites are used for mobile phones radio equipments.
Any idea?
Omar
Leo Laohoo Thu, 05/21/2009 - 15:30
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Omar,
Can you post the crashinfo?
omar.elmohri Thu, 05/21/2009 - 15:53
I cannot get the crashinfo as I have no access to flash. But here what I get:
Initializing flashfs...
flashfs[1]: 408 files, 8 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 8113664
flashfs[1]: Bytes available: 7885312
flashfs[1]: flashfs fsck took 9 seconds.
flashfs[1]: Initialization complete.
...done Initializing flashfs.
POST: CPU Buffer Tests : Begin
POST: CPU Buffer Tests : End, Status Passed
POST: CPU Interface Tests : Begin
POST: CPU Interface Tests : End, Status Passed
POST: Switch Core Tests : Begin
POST: Switch Core Tests : End, Status Passed
POST: CPU Interface 2nd Stage Tests : Begin
Frame storage failed on queue 0, even-byte frame
POST: CPU Interface 2nd Stage Tests : End, Status Failed
SYSTEM INIT: INSUFFICIENT MEMORY TO BOOT THE IMAGE!
%Software-forced reload
Omar
phamvudung Sat, 07/03/2010 - 19:29
I have the same problem with my Catalyst 3550-12T. The switch was operating properly before suddenly turned to be like that. A crash file was generated. I am trying to upload new IOS for it but I don't think it is going to help. It seems to be the hardware issue.
phamvudung Sun, 07/04/2010 - 04:27
I got the completely same problem. After desperately trying to upload serveral IOS file for the catalyst 3550-12T which is downloaded from cisco IOS center:
http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=12.1.19-EA1&mdfid=270568139&sftType=IOS+Software&optPlat=&nodecount=33&edesignator=ED&defInd=Y&modelName=Cisco+Catalyst+3550+12T+Switch&treeMdfId=268438038&modifmdfid=null&imname=&treeName=Switches&hybrid=Y&imst=N
The issues was not fixed.
I decided to boot the switch in rommon mode then:
load_helper
flash_init
delete all the configuration files
format the flash
run the check flash command
load the newest IOS images via xmodem: c3550-ipbase-mz.122-44.SE6 (it took me 3 hours to load the image to the switch via xmodem)
then set the default boot image to be c3550-ipbase-mz.122-44.SE6
then reboot the switch using the specified image. and I have no problem at all after that.
MAKE SURE YOU HAVE UNPLUGGED ALL THE CONNECTIONS FROM THE SWITCH BEFORE YOU RE-LOAD THE IMAGE OTHERWISE YOU WILL RECEIVE THE SAME ERROR MESSAGE WHATEVER IMAGES YOU GOT.
hope this help.
Leo Laohoo Thu, 05/21/2009 - 17:49
  • Hall of Fame,
    2017 LAN, Wireless
Hi Omar,
Try the command "dir flash:".
omar.elmohri Fri, 05/22/2009 - 02:47
I tried it and it show the file 'crashinfo' but I didn't find a way to copy it or to display it.
Leo Laohoo Sun, 05/24/2009 - 14:36
  • Hall of Fame,
    2017 LAN, Wireless
Hi Omar,
You can copy the file into your PC and post it here.
omar.elmohri Mon, 05/25/2009 - 14:59
As I said before. I found no way to copy the crashfile! as I can only connect with ROMMON and it's not possible to copy it using xmodem (which I tried by write on xmodem server is not permitted.
Omar
Leo Laohoo Mon, 05/25/2009 - 16:36
  • Hall of Fame,
    2017 LAN, Wireless
Hi Omar,
Can you post the output of the "dir flash:" command?
skint Mon, 05/25/2009 - 18:09
more flash:/crashinfo/crashinfofilename or just more crashinfo_, it depends on the version of code you're running. Dir flash: should give you filename to use your more against.
jorge.calvo Mon, 07/05/2010 - 00:44
  • Bronze, 100 points or more
Please note the line:
Please make sure your switch memory requirements (Flash and RAM) matches the ones the IOS needs. You may have to choose another IOS version or perform a memory upgrade on the switch.
Hope this helps. Regards.
