05-21-2009 03:16 AM - edited 03-15-2019 06:07 PM
We are using Unity connection 1.2 in which we have got a license file for 100 VM users alog with 16 ports(which will be simultaneously active).
In the same license file we have got UNITYCN1-VM-USR for value 25.What does this exactly mean?
i am attaching License file for reference.
regds,
aman
Solved! Go to Solution.
05-21-2009 04:11 AM
This is for an additional 25 users. So, you can support 125 VM users with this license file.
Hope this helps.
Brandon
05-21-2009 04:11 AM
Hope this helps.
Brandon
05-24-2009 08:50 PM
Hi Brandon,
We created 100 VM users.Accordingly,our licenses were consumed.
After that we tried creating more VM users but were unable to do so since the error message is coming "License Voilation :Subscribers".
It seems that we cannot create more than 100 users and 25 VM users as mentioned in Lic file , is something else.
regds,
aman
05-24-2009 09:50 PM
Hi Aman,
The best way to find this out is to get in touch with your accounts team.Since they would have final say in it.
Having said that i would like to know if you have rebooted the server after installing the new license file(Which i think you already have done)
I am attaching a ppt from previous post if it helps.
Again Accounts team can best explain the Jargon
05-25-2009 02:53 AM
Hi Brandon,
There was a problem in Licensing file.I received the new license file wherein I can add more users.
thanks.
regds,
aman
05-24-2009 10:00 PM
Also(in UC 7.0) under System settings-->licences on the top right pull the drop down to look at "view license usage" what does it say ?
