05-21-2009 05:56 AM - edited 03-06-2019 05:51 AM
I'm not sure what happened as I cannot console in or telnet into the router.
When I telnet into the router I get as far as:
Property of SunGard Futures Systems
No access or login permitted without explicit permission
from SunGard Futures IT Management.
Only authorized SunGard employees may
log on to this system
Any unauthorized use of the system is unlawful
and may be subject to civil and/or criminal penalties.
Use of the system may be logged or monitored without
further notice, and the resulting logs may be use
last I was in this router all I did was do a "show interface brief" to check on a interface. Ever since then that is as far as I get. How do I log in, I tried via the console but I get no response on the console as well.
05-21-2009 05:59 AM
You can try to SSH into it. If that doesn't work, you may need a reboot.
HTH,
John
05-21-2009 06:38 AM
Thanks John will try that but I have to wait till June 9th as we have a freeze in the data center. Thank you for the info....the ssh didn't work by the way.
