ERROR when I try to enable Top usage Status
smudholkar Sat, 01/02/2010 - 20:13
I was able to implement this via the ASDM GUI in the "configuration...threat detection" screen. From looking at your CLI command it would appear that 0 is not an option, you need to use an integer value between 1 and 3.
YANGCCIE4 Sun, 01/03/2010 - 09:08
1. try to use the  command #threat-detection statistics in CLI mode.
2, save the config disconnect and reconnect ASDM.
I have not met this situation, found a similar senario and resolution on the web.
hepe it works
Yang
