mahmoodmkl Thu, 05/21/2009 - 10:29
  • Gold, 750 points or more
It refers to the same thing.
Mahmood
carl_townshend Thu, 05/21/2009 - 10:54
hi
does the sup720 have onboard flash? or does it use the compact flash card?
littledavewhite Fri, 05/22/2009 - 00:53
no sure i presume just flash sup 720 purchased as default card with no external flash or memory upgrade, its just i have 4 systems some of them refer to supbootdisk and some sup-bootflash, i understand the external disk but a little confused by the other two options so you think it might be compact flash as apposed to normal flash ?
carl_townshend Fri, 05/22/2009 - 02:44
can anyone please confirm what the following are?
sup bootflash
sup bootdisk
disk:0
disk:1
and where is the default boot ?
cheers
Carl
nate-miller Tue, 05/26/2009 - 13:58
  • Bronze, 100 points or more
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Config_Notes/78_17277.html
Originally, the Sup720 used a DIMM-based flash memory stick for sup-bootflash.
These were capped at about 64MB, I think.
Once Compact Flash started to get cheap, cisco swapped the Flash dimm out with an adapter that took a CF card. This CF adapter is referred to as sup-bootdisk.
A box that has a sup-bootdisk can refer to that same CF card via sup-bootflash.
I don't think a box with bootflash has the ROM necessary to know about the sup-bootdisk, so there's no real forwards compatibility.
disk0: and disk1: are the physical CF slots located on the front of the supervisor.
carl_townshend Thu, 05/28/2009 - 02:57
soare you saying that they do not have ay internal memory, the flash/nvram is all on the cf card ?
