$$ Question about Gatekeeper$$
Answered Question
May 21st, 2009
Hello all,
I want to ask about, I have a gatekeeper and i make 2 zones each zone contain 3 gateways,and this gateways are used for voice, my question is, Can I assign different tech-prefix to each gateway at the same zone? or each gateway will has the same tech-prefix?
Thanks a lot.
Correct Answer by Brandon Buffin about 8 years 1 month ago
You can register different gateways within a zone with different tech prefixes using the "h323-gateway voip tech-prefix" interface configuration command on the gateway. So you could have:
Gateway 1
fas0/0
h323-gateway voip tech-prefix 2#
Gateway 2
fas0/0
h323-gateway voip tech-prefix 3#
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Thu, 05/21/2009 - 11:50
  • Purple, 4500 points or more
Gateway 1
fas0/0
Gateway 2
fas0/0
Hope this helps.
Brandon
