WAAS mobile with Vista
May 21st, 2009
Hi All,
when I turn on WAAS client on the windows Vista, the network connection is disconnected but it works with XP like a charm. any suggestion would be very appreciated.
drolemc Wed, 05/27/2009 - 11:06
I think it is layer1 connectivity problem. And ensure you have configured properly in the Network properties in the Vista. XP users cannot join a domain while Cisco WAAS Mobile client is running and Vista users cannot join a domain when the client is installed. Workaround: XP users should exit the Cisco WAAS Mobile client before trying to join the domain.
alex goshtaei Wed, 05/27/2009 - 11:11
Thanks for the reply,
I've upgraded to newest version of WAAS mobile and upgrade client as well and problem has been resolved. But still I have another issue, when I run Cisco VPN client with WAAS mobile enable, then I try to access to the web page intranet. I can ping web server IP address, I can access to the web page, but when I enter username and password, it doesn't let me to login. when I turn off WAAS client, I am able to login to intranet web page.
any suggetion?
