05-21-2009 10:26 AM - edited 02-21-2020 03:28 AM
ASA 5520
Multiple Context
I have an "Admin" and a second context named "simA." I've created a logical interface and allocated that interface to "simA" However, I cannot get any traffic to/from that interface and I'm seeing input errors on the switchport. The switchport is configured to trunk.
What am I missing? Attached ASA and switchport configs.
From the system space, ping to the default gw IP is successful. However, from the context it fails
lab-asa1# ping 192.168.100.1
Sending 5, 100-byte ICMP Echos to 192.168.100.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/10 ms
lab-asa1# ch cont simA
lab-asa1/simA# ping 192.168.100.1
Success rate is 0 percent (0/5)
Many thanks in advance!
05-27-2009 01:55 PM
The input packet drops may be due to exceeding VC's, No route to destination prefix, Incomplete ARP entry, Configured policy of an ACL
05-28-2009 12:33 AM
What is the native VLAN on the switch port FA 0/4?
Also post the admin-context configuration. And the 'show arp' output on the gateway device 192.168.100.1 immediately after pinging it from the ASA SIMA context.
Thirdly, you allocated GigabitEthernet0/2 to the context, but in the system context you defined a sub-interface for the same?
Regarding the input drops, check any speed/duplex issues between the two interfaces also. 'show interface'
Farrukh
