netconfig jobs failing
May 21st, 2009
I am scheduling jobs for automatted vlan change ; the job fails with the following Error - what should be the corrective action
"Command(s) failed on the device TFTP: Failed. Check the credentials are correct or TFTP server is running. Could not synchronize RME archive with Device Config"
Joe Clarke Thu, 05/21/2009 - 10:56
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
RME is trying to copy the desired config changes to the device using TFTP. The way RME does this is to use the CISCO-CONFIG-COPY-MIB to trigger a TFTP upload. Therefore, you need a valid SNMP read-write credential in DCR for this device. The device also needs to be reachable via TFTP from the RME server. This means UDP port 69 as well as all UDP ports > 5000 need to be open between the device and server.
gvk_kuttan Fri, 05/22/2009 - 14:21
one more job too failing in another device "Command(s) failed on the device TFTP: Failed on the device. Could not detect protocols running on the device" what should be the corrective action
Joe Clarke Fri, 05/22/2009 - 14:32
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You need to check what I mentioned before. In order for TFTP to work, you need to have a valid read-write SNMP credential in DCR for these devices, and you need to be permitting the required UDP ports.
