not able to access GUI of GSS
I m not able to access the GUI of GSS whereas i can ssh. Here is the show run output from GSS
Is there any way to troubleshooting the issue.
abc#sh run
interface ethernet 0
ip address zz.zz.zz.zz 255.255.255.128
gss-communications
interface ethernet 1
ip address t.t.t.t 255.255.255.0
hostname abc
ip default-gateway z.z.z.z
access-list acl2 permit icmp any
access-list acl2 permit tcp any
access-list acl2 permit udp any
access-group acl2 interface eth1
ssh enable
ssh keys
ssh protocol version 1
ftp enable
snmp-server trap-source ethernet 0
no cnr enable
drp
no enable
terminal length 23
exec-timeout 150
logging disk enable
logging disk priority Notifications(5)
no logging host enable
logging host priority Warnings(4)
logging facility local5
tacacs-server timeout 60
tacacs-server keepalive-enable
tacacs-server host y.y.y.y port 49 key j1b0ia
tacacs-server host x.x.x.x port 49 key j1b0ia
aaa authentication ssh local
aaa authentication gui local
aaa authorization commands
aaa accounting commands
I also added acls
access-list acl1 permit icmp any
access-list acl1 permit tcp any
access-list acl1 permit udp any
access-group acl1 interface eth0
still no luck
Overall Rating: 5 (1 ratings)
jecahuao Thu, 05/21/2009 - 17:24
  • Cisco Employee,
Hi, in order to access the GUI of the GSS, you have to activate the role of GSSM.
Try this command to verify if the device is already configured as GSSM.
You should get something like this:
#gss status verbose
Cisco GSS - 2.0(1) GSSM - primary [Fri May 22 01:00:16 UTC 2009]
Normal Operation [runmode = 5]
%CPU %MEM START SERVER
0.0 0.2 May01 Boomerang
0.1 2.7 May01 Config Agent (crdirector)
0.1 3.4 May01 Config Server (crm)
0.0 3.3 May01 DNS Server
If the device is not configured for the role of primary GSSM, you should follow the steps in the link bellow to activate it:
Configuring a Primary GSSM
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/gss4400series/v3.0/getting/started/guide/Setup.html#wp1059053
Keep in mind if you have more than one gss in the network, you should configure the role of gssm stand-by.
jc
My gss shows this output
gss status verbose
Cisco GSS - 3.0(2) GSSM - standby [Wed May 27 20:12:05 UTC 2009]
Registered to primary GSSM: 10.71.200.10
0.0 0.1 17:33 Boomerang
0.0 1.4 17:24 Config Agent (crdirector)
0.0 0.8 17:24 Config Server (crm)
0.0 1.6 17:33 DNS Server
0.0 0.3 17:24 Database
I believe .. i will not able to access the standby GUI and till the time it is standby state state correct ?
Once standby becomes primary then i will be will able to access GUI ..otherwise only cli access .. let me know if i am correct ?
You almost resolved my issue
jecahuao Wed, 05/27/2009 - 17:22
  • Cisco Employee,
Hi, based in the output provided, you should be able to access the GUI using this url in a browser <https://10.71.200.10>
The GUI is only available from the current GSSM primary. There should be only one primary in the setup at any given time.
SSH or telnet access is available all the time.
jc
