unity 7 with domino installation error "Unable to encrypt note password"
May 21st, 2009
I am installing cisco unity 7.0.2 with lotus domino as the message store. During message store configuration wizard i get error message "Error encrypting notes password"
mohit-singh Thu, 05/21/2009 - 21:39
Message Store Configuration Wizard was unable to complete since it gave me error "Unable to encrypt notes password" when i enter notes user password. So there is no MSCW in add/remove programs.
I checked the syscheck log and it says "lotus notes password not in registry". But i am able to log into notes using the same password.
navinger Fri, 05/22/2009 - 09:55
We've seen some problems with the Notes password encryption in Unity 7. I was cc'ed on an email on this issue not too long ago, and the engineer said:
"The issues with the password have been related to a GPO / account issue with the OS.
On 2003 they can use : 'whoami /priv' to make sure the backup and restore privs are listed. It can be either enabled/disabled, it doesn't matter, what matters is that it is listed. If it is not listed, then they need to add that priv then all should be good."
I don't know anything about "adding privs" -- but maybe you do, or maybe somebody else could fill in the details?
Please keep me posted on the outcome.
