Unity 7.x
I see where Unity 7.X has an option for Partitions and Search Spaces. I was able to create two user accounts with the same extension with different Search Spaces/Partitions. Is there a way that I can divide out the ports and a second voicemail profile so we can keep 4 digit dialing with site codes? Seems that our current version 2.01 does not allow for duplicate extensions. Trying not to have to change the current 1200 users that are in our Unity Connection server.
Thank you in advance
Scott
