05-21-2009 01:34 PM - edited 03-15-2019 06:08 PM
I have a lobby phone that is attached to an FXS port and want to use COR to limit the user to internal, 911 and local calling. Basically block LD. How do I attach the COR list to the FXS port? The examples attach it to an ephone-dn.
05-22-2009 11:23 AM
Since you are not using the FXS port in SCCP mode, the simplest thing is to configure a voice translation-rule and translation-profile that rejects calls beginning with the LD prefix. You apply it directly under voice port.
05-26-2009 04:25 PM
If you want to use the example, just make this modification:
voice-port 0/0/0
station-id number 1234
dial-peer voice 1 pots
answer-address 1234
corlist incoming
-nick
