Using COR to Limit a lobby phone attached to an FXS port
May 21st, 2009
I have a lobby phone that is attached to an FXS port and want to use COR to limit the user to internal, 911 and local calling. Basically block LD. How do I attach the COR list to the FXS port? The examples attach it to an ephone-dn.
Adrian Saavedra Thu, 05/21/2009 - 13:58
  • Gold, 750 points or more
Configure your FXS ports to be controlled by CME using SCCP protocol.
Best regards,
- Adrián.
redrobish Thu, 05/21/2009 - 23:40
yes, Andrian is right! you can use COR list with call manager express.COR is similar to CSS in CUCM. So it depends on your options.
hth
presgargary Fri, 05/22/2009 - 06:01
I will give it a try and then post my config. Thanks very much for the direction.
paolo bevilacqua Sat, 05/23/2009 - 14:14
  • Hall of Fame,
    Founding Member
I think you had asked this already.
It is not necessary to configure SCCP to limit calls from an FXS port.
The simpler method is to apply a voice translation-profile that rejects calls to blocked prefixes.
presgargary Mon, 05/25/2009 - 16:42
Thanks for the replies. I hadn't asked this question before, but used a translation on the calling number and assigned it to the outbound LD dial-peer. It works great. Thanks all. I want to try to get the sccp to work, I already have it running for rsources.
Gary
