Previously Entered IOS Commands Missing from Sh Run Output
May 21st, 2009
On more than one occasion my colleagues and I have noticed that commands successfully accepted on interfaces don't show up in the show run output, i.e. I have put ip hello-interval eigrp 11 60 and ip hold-timer eigrp 11 180 on GRE tunnel interfaces on my branch 3725 router and my Core 6500 router. On occasion, I will not see the commands on the interface when I enter a show run. Is this a bug of the 122.33. SXF?
Giuseppe Larosa Fri, 05/22/2009 - 13:00
Hello Matthew,
EIGRP defaults to hello 60 seconds hold 180 seconds on multipoint interface with bandwidth <= T1.
if the GRE is considered multipoint and BW is less then T1 the values are not showed because they are the default values.
Are you using multipoint GRE with DMVPN ?
Hope to help
